Hi, Please I need help! Just replaced the -PCB- (Printed curcuit board)# 6871W1S128C. There are 4 wire plugs to connect to the board. 3 of which are murphy proof connections so no problems there. The last is a 2 spade female connector for RY2. Problem is I didn't mark it when seperated it from the board. The female plug, to plug onto the board, has one side with a black & a yellow wire - the other has a black & a red wire. what is the correct orientation of the female plug to the RY2. I am looking at the connection side of the PCB with the RY2 in the lower right corner. Thanks for the help rcsch5056 attached the following image(s):
