bwatty
#1 Posted : Monday, August 29, 2011 1:44:58 PM(UTC)
bwatty
Recently water inlet to icemaker froze causing water to spray inside freezer. Removed assembly, thawed and reassebled. Icemaker filled but will not eject.
Freezer temp 0 deg. Optical sensor shows solid red when flapper closed. No volts at TP, no volts at Molex connector.
Ideas?
#2 Posted : Monday, August 29, 2011 4:38:54 PM(UTC)
Originally Posted by: bwatty Go to Quoted Post
...Recently water inlet to icemaker froze...
...Icemaker filled but will not eject...
Sounds like there is two separate problems.
The first problem is a bad water inlet valve and, very likely, the second problem is a bad ice maker.
- The water inlet valve Part number: AP4454644
bwatty
#3 Posted : Monday, August 29, 2011 5:44:28 PM(UTC)
bwatty
How does malfunction of either of those parts result in 0 volts at the molex connector?
#4 Posted : Tuesday, August 30, 2011 3:21:01 PM(UTC)
How did you measure it?
bwatty
#5 Posted : Tuesday, August 30, 2011 7:11:59 PM(UTC)
bwatty
Voltage not an issue anymore. Was looking for vDC instead of vAC. Replacing icemaker.
#6 Posted : Wednesday, August 31, 2011 3:45:36 PM(UTC)
The frozen water line, you mentioned earlier, points to the problem with the water inlet valve.
