A quarter has slipped in under the drum a makes a loud racket when the machine spins. Will removing the door gasket allow me access to it or must I somehow remove the drum itself. THKS!
I am afraid the answer is we don't know, but go ahead and remove the gasket and see if you can get to it. Note very carefully how the gasket comes off because it is a bear to get back on. Try to have some help.
Good luck.
