Frig compartment maintains the "Set Temp" at all times (normal). Freezer compartment maintains "Set Temp" for a day or so then temp slowly increases from 0 degrees to as warm a 16 degrees. No new ice...old ice and icecream become soft. Then, freezer strarts working again right down to the 0 degree set temp. Does this have something to do with the auto-defrost or something else?
