Greetings- I need to find a source for oven door hinges for an older (new in 1991) Viking freestanding range. These are NOT the compound hinges with the spring already attached. These are stamped from sheet steel, with a post welded on to one piece and a hole punched into the other. The long piece with the post simply rotates in the short piece with the hole. (The spring is horizontal and attached only to the right-side hinge. There never was a hinge on the left.) After 18 years, the posts are simply worn down. I've searched the web and can only find the compound hinges, which don't fit. Any ideas where to get these hinges? Thanks sdpaddlebum@gmail.com attached the following image(s):
