Can I fix this problem by myself? Here is the diagram for the Amana ABB 2527DEW freezer drawer. It is a pull out freezer bottom drawer. The two metal clips on one side have disconnected so the handle is unhinged. Do I have to take the door apart to repair? Thanks, tmrowka
I'm not very familiar with this model, especially with the door handle. Maybe somebody else on the forum can help you better.
thanks, I hoe someone can help:)
THIS FORUM IS DEAD!!!!!!! |
thanks that should do the trick:)
Originally Posted by: tmrowka thanks that should do the trick:) Please share how you fixed the handle. I have the same issue. thanks.
