easye
#1 Posted : Wednesday, June 22, 2011 7:42:28 PM(UTC)
easye
My oven just recently stop heating up. I noticed that the heating element lights up, but the gas does not flow into the oven. First I checked the wiring which seems to be fine. Then I tapped on the oven safety valve which then came on and started the gas flow into the oven. I ordered a new valve and installed it which was very easy, but it does the exact same thing. If I tap on it, it comes on. Any answers before I return this part?
Joe / APP Team
#2 Posted : Thursday, June 23, 2011 12:10:05 PM(UTC)
Joe / APP Team
Easye,
You most likely have a weak glow bar igniter,
Part number: AP4096256
When you tap on the valve body, you're forcing the valve switch to open.
When 120 VAC is supplied to the igniter, from the control, and the glow starts, it has to draw 3.2 to 3.6 amps, and supply 3.2 to 3.6 VAC to the terminals on the bake valve in order to open the internal switch, and release the gas for ignition and burn.
You could have a weak igniter, it will glow but not produce enough amperage or voltage to open the valve.
:cool: :cool: :cool:
easye
#3 Posted : Thursday, June 23, 2011 12:54:32 PM(UTC)
easye
Thanks, I just ordered the the ignitor and will give it a shot.:)
Joe / APP Team
#4 Posted : Thursday, June 23, 2011 1:18:00 PM(UTC)
Joe / APP Team
Easye,
OK,
Good Deal, you should be up and running soon.
Upper Maytag oven won't heat (Oven Repair (including Ranges and Cooktops))
by tfuertes 2/28/2012 4:28:57 PM(UTC)
Maytag Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by Petezr 1/25/2012 6:27:38 PM(UTC)
Maytag oven won't heat up (Oven Repair (including Ranges and Cooktops))
by steelerfan349 10/22/2010 2:42:24 AM(UTC)
Maytag Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by Miken47 6/5/2010 8:50:29 AM(UTC)
Maytag Oven Won't Heat After Self Clean Cycle (Oven Repair (including Ranges and Cooktops))
by blindab 12/1/2009 6:57:24 AM(UTC)
maytag oven won't heat (Oven Repair (including Ranges and Cooktops))
by blonda1972 4/6/2009 2:38:22 AM(UTC)
