2 Pages12>
frantab
#1 Posted : Monday, February 23, 2009 6:03:38 AM(UTC)
frantab
I have an interesting problem. My cat hates his new litter, and pretty much refuses to use it. What he decided to do was pee on the stove. Unfortunately, he pee'd on the burner that has a pipe leading down to the oven and the insulation that surrounds the oven. So now the insulation reeks of cat pee. Is it possible to replace that insulation? Any help would be greatly appreciated.
Thank you
TechnicianBrian
#2 Posted : Monday, February 23, 2009 11:24:09 AM(UTC)
TechnicianBrian
Most ovens has insulation blankets that can be replaced, it's just some are easier to do than others. If you provide a make and model number, we can point you in the right direction.
frantab
#3 Posted : Monday, February 23, 2009 12:21:50 PM(UTC)
frantab
It is a Roper FEP320. Thank you.
TechnicianBrian
#4 Posted : Monday, February 23, 2009 5:36:05 PM(UTC)
TechnicianBrian
There are several versions of that model, so I will need the entire model number from the serial plate to ensure I am providing the correct information.
#5 Posted : Tuesday, February 24, 2009 4:02:38 AM(UTC)
Brian
Could you just remove some of the insulation and then just repack it instead of replacing the whole blanket?
Sounds like it is time for some cat chow mein!!!
Denman
TechnicianBrian
#6 Posted : Tuesday, February 24, 2009 5:31:22 AM(UTC)
TechnicianBrian
Denman,
That is a good idea, but my thoughts are if the cat spent enough time on the range that the customer is noticing the smell, I wound imagine the blanket has been wicking the urine and is most likely is bad shape. Of course forgetting the insulation, what do you suppose the vent tube and oven cavity look like?
frantab
#7 Posted : Wednesday, February 25, 2009 9:59:44 AM(UTC)
frantab
where would i find the serial plate on it? this is the type it is if it helps any. thanks for all your guys help.
Roper FEP320 Electric Range Reviews. Buying Guides & Consumer Product Reviews - Epinions.com
#8 Posted : Wednesday, February 25, 2009 10:41:24 AM(UTC)
frantab
#9 Posted : Wednesday, February 25, 2009 10:50:55 AM(UTC)
frantab
thank you for that, i remember seeing something similar, but couldnt find it again.
MODFEP310EW
RH0232603
thank you again for your help. somewhere else i looked pointed me towards this:Range Insulation
#10 Posted : Wednesday, February 25, 2009 2:04:42 PM(UTC)
For future reference your Model is a FEP310ew
Model FEP310EW0
I think you need AP3065954 Item 24 in the "Chassis" section.
Perhaps TechnicianBrian can confirm this
I have no experience with the link yow included.
Replacing oven insulation soiled by mice (Oven Repair (including Ranges and Cooktops))
by klandingham 11/6/2022 7:05:45 AM(UTC)
Oven Insulation (Oven Repair (including Ranges and Cooktops))
by dancingbrook 4/1/2011 8:24:34 PM(UTC)
Oven insulation wrapper discont. - Can I customize another brand wrapper? (Oven Repair (including Ranges and Cooktops))
by Elizabeth10 1/3/2011 11:50:53 AM(UTC)
Oven Insulation Replacement (Oven Repair (including Ranges and Cooktops))
by sjeffries 3/16/2009 1:45:30 PM(UTC)
by Hagemoj 9/29/2008 6:30:50 PM(UTC)
2 Pages12>
