jeffro390
#1 Posted : Monday, June 6, 2011 9:26:31 AM(UTC)
jeffro390
the oven and broiler do not work. the cook top does and the digital clock. when you push the button for bake or broil the oven doesn't cycle to the temp setting. you can hear the oven beep when the buttons are pressed for the oven/broil.
thanks
Jeff
freygreer
#2 Posted : Monday, December 28, 2015 12:57:10 PM(UTC)
freygreer
Just had the same problem with my Maytag MER5755QAQ Stove. The bake and broil did not come on. The top stove burners worked. It is easy to determine what the problem is. First take the back off and with a multimeter set to read ohms test each element by taking the multimeter and measuring across the element stabs on the back that the wires are connect to. If the element is good, the multimeter should not show OL on the display. If the elements are good next check the temperature probe. The probe is located in the oven on the top left corner. You will see a plug where the probe plugs into. Unplug it and with the multimeter measure across the probe plug and you should not see OL if the probe is good. If you do get OL you will need to order a new one. My probe was bad and it cost me 28.00 on line. Once I replaced the probe the oven worked again. If everything checks out ok that I told you to check then you may not be getting a full 240 volts to the stove. If you are getting 240 volts then the problem is probably the control board which is expensive. Hope this helps.
