Builder99
#1 Posted : Monday, May 23, 2011 3:13:07 PM(UTC)
Builder99
No heat. With the door closed and unit trying to work, is there any reason that the voltage to the primary leads of the HV transformer should be anything but line voltage ? I have line voltage on one primary lead to ground, but only 15.3 V between the two primary leads. I am beginning to suspect the triac in the power module. Do you think I might be on the right track ? Thank you.( and yes, the capacitor is discharged).
#2 Posted : Monday, May 23, 2011 6:49:05 PM(UTC)
I don't have the electrical schematic for this model but, as far as I remember, the neutral line to the power transformer comes through one of the door switches.
Here are the breakdown diagrams and Replacement parts for General Electric JKP66G*01 Electric range | AppliancePartsPros.com
