When I run my washer, the cycles don't advance. It will just keep running until it overflows, unless I manually advance it. I replaced the timer, but am still having the same problem. What could be wrong?
Check the tube running from the water level switch to the tub and clean it out and clean out where it connects to the tub. If that does not fix things try replacing the switch, this part here Part number: AP3867022
