pkme
#1 Posted : Monday, January 26, 2009 9:54:13 PM(UTC)
pkme
Hello-
I have a Kenmore washer, model 110.26712690 that will not agitate or spin. I decided it might be the motor couplings, which I actually have had to replace before. After disassembling the washer, I did find some black shavings underneath the washer. I had an AWFUL time trying to remove the pump--the drive motor shaft & the part it fits into on the pump are both extremely rusty.
I've now removed the drive motor, & the isolation & couplings are definitely disintegrated, but I am wondering if I'm going to need to replace the pump as well. What has caused it & the drive motor shaft to get so rusty?
Thoughts? Feedback?
Thanks in advance.
PK
#2 Posted : Tuesday, January 27, 2009 12:38:29 AM(UTC)
You have a leaky pump, just remove the clips and pound the pump off carefully to prevent damage to the motor. You will need a file and emory paper to clean off the rust from the motor shaft
pkme
#3 Posted : Tuesday, January 27, 2009 6:55:25 AM(UTC)
pkme
Thanks-
Will order a new pump, too. Anything else you think I need to check? I'm definitely a novice with repairs. I appreciate your help.
PK
