HI, Clock overlay accepts command functions but does not execute any. The clock itself works. The surface burners work. Thanks. Bob
Originally Posted by: Robert Oswald HI, Clock overlay accepts command functions but does not execute any. The clock itself works. The surface burners work. Thanks. Bob Bob, Do you recall any failure codes being displayed ? Does the ERC / clock program and display the temperature selection,etc. Have you tried to program a Broil cycle, and does it work ? This being a "gas" oven, it could be as simple as a weak/bad igniter on the bake burner. Part number: AP4012072
Thats where we need to start, if the ERC is programming, proper. :) :) :)
