Patricia Ratliff
#1 Posted : Sunday, January 11, 2009 9:55:50 AM(UTC)
Patricia Ratliff
my top loading washer will not drain or spin. I noticed a few months ago that it did not drain or spin on the delicate cycle only but now it is not draining and spinning on any of the cycles.
Please advise.
kayakcrzy
#2 Posted : Sunday, January 11, 2009 1:43:35 PM(UTC)
kayakcrzy
If it runs, and does not drain, you could very well have a broken coupler. Unplug the washer, and pull it away from the wall, and then lean it back, and rest it there. Then go underneath with your flashlight, and look behind the motor, you will see the coupler. One piece is mounted to the motor, with three nipples, and then you will see a black rubber piece mounted to it, and there will be another piece with three nipples mounted on the transmission. Make sure the nipples or the rubber is not broken. If all is well, remove the pump, and see if it is not clogged. get a 3/8s extention, and put it in the shaft of the pump, and turn it, and see if it turns. The pump is held on by a upper and lower clip. Tom ApplianceEducator.com
Patricia Ratliff
#3 Posted : Monday, January 12, 2009 4:34:31 AM(UTC)
Patricia Ratliff
Thank you immensely, I have printed your reply and will follow it to a "T".
You made my day.
kayakcrzy
#4 Posted : Monday, January 12, 2009 4:46:06 AM(UTC)
kayakcrzy
Thank You, I am glad to help. Tom ApplianceEducator.com
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave Yesterday at 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave Yesterday at 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave Yesterday at 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
Samsung top load washer won’t start (Washer Repair)
by aw2055989 4/19/2024 4:42:33 AM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag LA882 Washer (Dishwasher Repair)
by soloRepairer 3/30/2024 2:12:38 PM(UTC)
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
