Dadrocks40
#1 Posted : Sunday, March 27, 2011 7:29:19 PM(UTC)
Dadrocks40
Water won't stop running when you're filling the tub on the wash cycle and the rinse cycle.
sidfink43
#2 Posted : Tuesday, March 29, 2011 5:21:48 PM(UTC)
sidfink43
If the water will stop running when you stop the machine, clean out the tube going from the water level switch to the tub. If that does not fix things, and most of the time it does, then try changing the water level switch.
Also, check to see that the tube is not pinched off, had one of those just the other day.
Dadrocks40
#3 Posted : Saturday, April 9, 2011 10:39:47 PM(UTC)
Dadrocks40
Thanks, I replaced the water level switch and problem solved.
sidfink43
#4 Posted : Sunday, April 10, 2011 4:43:24 AM(UTC)
sidfink43
Great, glad you got it fixed and thanks for updating us.
