We recently had 2 weeks of frozen temperatures in our area. Our machine is located in a cold out-building and I disconnected the water source during the freeze. I did a load successfully several days ago with no problems. Today, after moderate freezing temperatures and the water hooked up (30 degrees) - the water comes into the machine and cycles out immediately. In other words - the machine won't fill up. Did I freeze a part?
I would imagine the water vale has water in i, tand it is frozen. Get out the blow dryer. Tom
