Fridge door will not swing shut. Food gets warm. Has slight backward angle tilt. Stops about an 1" from closing, must then push shut.
TIA
Cannot find any info on the given model number, please check it. ED comes up as a dehumidifier.
Most units have a set of cams at the bottom hinge of the door perhaps one or both of these are broken. |
THIS FORUM IS DEAD!!!!!!! |
