DJrFam
#1 Posted : Saturday, March 19, 2011 1:32:13 PM(UTC)
DJrFam
Our oven door is broken. First, It wasn't closing all the way and then finally the door fell off. The handle broke when the door fell on the floor. We removed the door to fix the handle. While we were trying to fix the handle, the glass shattered. I would like to know if I can purchase just the door itself, just the glass or do I need to purchase a whole new oven. Thank you for your help.
#2 Posted : Sunday, March 20, 2011 5:14:51 AM(UTC)
DJrFam
#3 Posted : Sunday, March 20, 2011 11:49:57 AM(UTC)
DJrFam
Thank you so much. We found the parts we need. But now I have a new question. The reason we had to remove the door was because the oven door wasn't closing all the way.
We are still going to have a problem with the door not closing all the way.
How can we make the door close all the way?
Thanks!
#4 Posted : Monday, March 21, 2011 2:54:58 AM(UTC)
[COLOR="DarkRed"]
How can we make the door close all the way?[/COLOR]
Check the hinges perhaps one of them has a problem.
Often just removing the door and re-installing it fixes closing problems as one or both of the hinges have slipped out of alignment. Be sure to use the recommended procedure for reinstalling the door.
I rare instances the hinge receiver has a problem.
Whirlpool oven door latch motor (Oven Repair (including Ranges and Cooktops))
by sparkync 8/1/2015 12:10:39 PM(UTC)
Whirlpool Oven Door Hinges Continuously Fail (Oven Repair (including Ranges and Cooktops))
by togamac 10/4/2012 8:50:36 AM(UTC)
Whirlpool oven door removal (Oven Repair (including Ranges and Cooktops))
by ts756 8/17/2012 12:55:14 PM(UTC)
Whirlpool oven door light switch (Oven Repair (including Ranges and Cooktops))
by Jim Yoshino 10/18/2011 9:37:20 AM(UTC)
Whirlpool oven door fell off (Oven Repair (including Ranges and Cooktops))
by richappy 4/8/2011 12:47:53 PM(UTC)
Whirlpool Oven Door Latch (Oven Repair (including Ranges and Cooktops))
by rwbil 1/16/2011 6:01:23 AM(UTC)
Need help assembling Whirlpool oven door handle (Oven Repair (including Ranges and Cooktops))
by SauravSengupta 10/30/2010 7:29:55 AM(UTC)
Whirlpool Oven Door Glass Removal (Oven Repair (including Ranges and Cooktops))
by hkrauss 7/29/2010 1:50:51 PM(UTC)
Whirlpool oven door hinge pins (Oven Repair (including Ranges and Cooktops))
by Earnesttphdthc 8/13/2009 9:19:42 AM(UTC)
Whirlpool Oven Door Help (Oven Repair (including Ranges and Cooktops))
by RitaCStanley@aol.com 7/3/2009 4:40:03 PM(UTC)
Whirlpool Oven Door Switch - How To Replace? (Oven Repair (including Ranges and Cooktops))
by amorak 12/13/2008 3:18:33 PM(UTC)
Need Help With Whirlpool Oven Door (Oven Repair (including Ranges and Cooktops))
by Wardog1958 10/6/2008 3:19:53 PM(UTC)
whirlpool oven door (Oven Repair (including Ranges and Cooktops))
by ronald 4/25/2008 10:11:41 AM(UTC)
Whirlpool oven door too hot (Oven Repair (including Ranges and Cooktops))
by danmari5 1/29/2008 8:01:56 PM(UTC)
Loose Whirlpool Oven Door Handle (Oven Repair (including Ranges and Cooktops))
by konaboy 1/10/2008 8:13:53 AM(UTC)
