jmy1951
#1 Posted : Thursday, December 18, 2008 6:37:05 PM(UTC)
jmy1951
Compessor works, lights all work, thermostat clicks, new evaporator fan flickered on but quit. Evap. coil was iced up. Both sides were hot. This is an Amana sidexside made for Kenmore. After I put new fan on and cut refg. on, new fan did not work.
libertyappl
#2 Posted : Thursday, December 18, 2008 7:37:24 PM(UTC)
libertyappl
Did you fix the defrost problem?
Most likely the defrost thermostat. Part Details - MAYTAG Thermostat, def, part number: R0161087
Nat
jmy1951
#3 Posted : Thursday, December 18, 2008 8:01:25 PM(UTC)
jmy1951
:confused:
Thermostst looked ok. No swelling. Is there a defrost timer or motherboard on this model. Thanks for your help.
libertyappl
#4 Posted : Friday, December 19, 2008 7:32:17 AM(UTC)
libertyappl
Yes, this part Part Details - WHIRLPOOL CONT- ADAP, part number: 12050506 is in the back near the compressor.
Nat
jmy1951
#5 Posted : Monday, December 22, 2008 7:53:37 PM(UTC)
jmy1951
Will a bad Bi-metal thermostat keep the evap. fan motor from working? Thanks. Will advise, waiting on part.
libertyappl
#6 Posted : Tuesday, December 23, 2008 5:37:41 AM(UTC)
libertyappl
A bad defrost thermostat, bi-metal, is part of the defrost system. If it is bad then it will not go into defrost cycle. The evaporator fan doesn't run while in defrost cycle.
Nat
jmy1951
#7 Posted : Thursday, December 25, 2008 1:44:55 AM(UTC)
jmy1951
Replaced bi-metal thermostat, Didn't help.
Compressor runs, evap. coils get cold.
New evap. fan doesn' t come on
