george405
#1 Posted : Thursday, February 17, 2011 8:01:33 AM(UTC)
george405
The tub fills up and starts coming out the bottom of the door and isn't draining at all but when I press cancel and drain it pumps right out .
Jeff / APP Team
#2 Posted : Thursday, February 17, 2011 9:38:10 AM(UTC)
Jeff / APP Team
Sounds like you might have a bad float switch. First check the float in the front right side and make sure it is not stuck. If it is free the go to the bottom and check the switch with a multi-meter for continuity. NC should be closed and NO should be open. If it reads bad replace it. Here is the part number along with the parts diagram. Hope this helps.
Part number: AP2909457
george405
#3 Posted : Thursday, February 17, 2011 12:58:54 PM(UTC)
george405
Thanks I will try that in the morning, it makes sense.
Jeff / APP Team
#4 Posted : Thursday, February 17, 2011 12:59:57 PM(UTC)
Jeff / APP Team
Your welcome. Let us know how it turns out.
