Replacement parts for General Electric DPSR483EA1WW Electric dryer | AppliancePartsPros.comGE likes to keep all tech info a secret so I cannot find specific info on this unit.
Below is a link to a fairly standard GE unit, it should at least give you an idea of how GE does things.
http://www.applianceaid.com/image/geediagram.JPGCheck inside your control console, often that is where wiring diagrams are stored.
[COLOR="DarkRed"]
This dryer was given to me,. I was told it was slow at drying. I pulled the drum out so that I could check the elements, they are good.[/COLOR]
When checking the elements, did you use a meter?
Also did you disconnect at least one side of the element you were checking just to be sure you were not reading an alternate/parallel circuit path.
[COLOR="DarkRed"]
but only one element came on through about four cycles.[/COLOR]
I am assuming you mean 4 heat/fabric settings.
[COLOR="DarkRed"]What could be causing this problem?[/COLOR]
Could be a bad thermostat, at least that is where I would start.
Nezt woyuld be the temperature/fabric selector switch.
[COLOR="DarkRed"]If it is a thermostat how do I know which one? Is there a way of testing these?[/COLOR]
You have 3 on the heater (Section 4 in the parts) and one on the blower (Section 1).
All of them should be 0 ohms at room temperature.
