luisd
#1 Posted : Wednesday, January 12, 2011 3:46:28 PM(UTC)
luisd
i own a ge profile model number js998sk1ss, suddenly the display board went off with no clock, no mumbers to click, no beep, anythig. i can steel use the cooktop, is the oven that is not working. There are so many boards inside of the unit that i dont know where to start. Could it be the touch panel? or some of the boards? maybe a fuse(that would be the easy and cheap way...)
i will apreciate your help in this matter,
Luis
luisd
#2 Posted : Thursday, January 13, 2011 8:09:45 AM(UTC)
luisd
Please help
#3 Posted : Thursday, January 13, 2011 12:47:57 PM(UTC)
The first thing I would do is remove the power from the range for a few minutes. Sometime it helps to eliminate the problem.
luisd
#4 Posted : Thursday, January 13, 2011 2:28:20 PM(UTC)
luisd
Thanks for your reply, I did everething you just said, from disconencting the unit for more than a half of hour to unplugging all the boards behind the display board. Still not working, i think is not a power issue because the cooktop is still working.
Thanks again for Your help
#5 Posted : Thursday, January 13, 2011 3:29:12 PM(UTC)
Did you find the mini manual/tech sheet?
luisd
#6 Posted : Thursday, January 13, 2011 3:53:57 PM(UTC)
luisd
No, is nothing there, at least behind the board and all the stuff there.
Thanks again.
#7 Posted : Friday, January 14, 2011 2:43:42 PM(UTC)
This range not very simple. You have to run a few tests with a good voltmeter to diagnose the problem. Let me know if you feel comfortable doing such tests with the range powered up and I will provide the instructions for you.
luisd
#8 Posted : Friday, January 14, 2011 3:03:03 PM(UTC)
luisd
Its fine, i just need to get one so ill reply when ready to working with it.
Thanks for your help
