A few weeks ago I noticed the Lower Spray Arm in My Frigidaire Dishwasher had melted on one end. Ordered the part and installed. Now I notice that no water sprays out when the DW runs? Water is filling the bottom of the tub, DW runs through it cycles, heater coil heats up, steam inside the tub, but none of the dishes get wet. I did remove and clean the filter and looked for any bits and pieces. The water supply line is hot so I assume water flowing ok. I guess the Lower Spray Arm was the “Canary in the Cage” for another issue!! Hope you can help! Many thanks! :eek:
