Until recently, the Refrigerator door (not freezer side) on my 19 year old HotPoint refrigerator ( model CSX22GMA ) does not closed tightly as soon as the door was released. Now, the door frequently stops about an inch short of the seal. Any idea why? I don’t see bottom part cam. I see the hinge lip where the bottom cam sits on or is it one piece? The top cam is worn compared to the Freezer door top cam. The frig door has drops about a ¼ inch and is misaligned with the Freezer door. Which parts numbers do I need? Think its part#16, but is that for both top and bottom or? Thank you
That is exactly what you need, part 16, door closer cam, just order it here.
Thank you....Do I need two cams. A top and bottom that fit into each other? Is the cam 2 pieces that slide over each other, like the freezer side has? It looks like the top is worn off.Thank you.
