What is the procedure for replacing the main top and right front burner on my Frigidaire GLEC36S8EBB cooktop? How do I remove the cracked top? How is it secured?
THIS FORUM IS DEAD!!!!!!! |
I have the replacement parts in hand. I just need to get the old top off and put on the new top and one new burner. Looks like I have to remove the entire unit from the cabinet and see how the top is attached (screws, welded???). I can not tell from the bottom.
