Groups ready for retrieval: Registered
I have on signal on the console. I checked to ensure I had power and the washer was properly plugged in. There are no lights on the control console or the led display. I purchased a new console/led w/membrane but that didn't correct the problem. I have not yet replaced the circuit panel. Would that be the likely problem?
Originally Posted by: preplexed I have on signal on the console. I checked to ensure I had power and the washer was properly plugged in. There are no lights on the control console or the led display. I purchased a new console/led w/membrane but that didn't correct the problem. I have not yet replaced the circuit panel. Would that be the likely problem? It is likely the main control board. Expensive, but better than buying a new washer.
