My range (with controls in the front) has a bad switch that I need to replace. I've found the part (54A on the diagram) but I cannot figure out how to get to the underside of the control panel. I've seen answers for similar questions here, but the unit is different from mine. There are no screws on the side of the unit like there are on some others.
Thanks.
