Welcome Guest! To enable all features please Registers on the forum or Register.
nealtee1934
#1 Posted : Sunday, November 16, 2008 2:41:27 PM(UTC)
nealtee1934
When trying to start oven for baking, the panel display shows just a series of dots. Setting the temp results in the display showing the temp selected, then, after about 10 seconds shows 100 degrees. Nothing happens after that. Oven does not ignite. Have checked connections, and breaker. all ok. Oven worked perfectly yesterday. Today, won't start. What could have happened and what do I do to repair it?
#2 Posted : Monday, November 17, 2008 5:40:14 PM(UTC)
Most likely the problem is a bad Bake igniter. Remove the bottom drawer, disconnect the igniter wires and check the igniter for continuity. Replace if it's open.
- The part number for the Bake igniter is AP2014008
