WaltnCampSwampy
#1 Posted : Saturday, November 20, 2010 5:11:03 PM(UTC)
WaltnCampSwampy
Howdy, Foax! Trying to troubleshoot an electric dryer with a Sperry DM-4100A digital multimeter. After isolating the heater coil circuit to perform a continuity check, I was perplexed by instructions which read, "Remove leads, set VOM on R1, and probe terminals. Look for reading of 5 - 25 ohms. If reading is 0, replace coils." Following these instructions exactly, I get a reading on R1 of 0.10 ohms. However, considering that the juice pulsing through these coils is around 220V+, and the coils' resistance should be 5 - 25 ohms for proper operation, I'm thinking that the proper range/function switch setting should not be R1, but at least R20. Do I know what I'm doing?
Regards, Walt
#2 Posted : Sunday, November 21, 2010 12:08:49 AM(UTC)
I looked up your meter and did not see an R1 setting.
http://www.sperryinstruments.com/documents/products/dm-4100a.pdf
Lowest setting I see is 200, this scale will read from 0 to 200 ohms.
Set it to this scale.
Note the reading, this is what you get with infinite ohms (open).
Now short the meter leads together, you should see a 0 or something like 0.00 etc. This is a dead short.
WaltnCampSwampy
#3 Posted : Wednesday, December 8, 2010 10:47:58 AM(UTC)
WaltnCampSwampy
Thanks for the refresher, Denman! Next time I'll go for an idiotproof, autoranging Fluke. Your assistance was helpful, informative, and very sincerely appreciated.
Best regards, Walt
#4 Posted : Thursday, December 9, 2010 4:17:43 AM(UTC)
You are welcome
Hopefully your unit is now up and running.
