Whirlpool gas stove 1999- Broil & surface burners work fine, But no baking gas or ignitor. I removed the safety/regulator valve as it seems to control both the gas & ignitor. Tech sheet shows it controls the ignitor until it is heated then allows gas, the part number is 3196433. Am i on the right track before I spend $150 for this part. Hurry Turkey is still cold...
I swapped the broiler igniter (Know good part) to the lower baking flame tube and it worked. Saved $ by this trouble shooting as the Valve was $152+ versus $ 50 for an igniter. Turkey soon to be hot...
Display works, it was the igniter-thanks!!
