2 Pages12>
lgb1243@msn.com
#1 Posted : Saturday, November 8, 2008 7:59:41 AM(UTC)
lgb1243@msn.com
My dishwasher has one spray arm that will not rotate. I have cleaned the filter on the bottom of the basin but am wondering how to remove the spray arm without breaking off the two tabs that hold it down in place? I have tried pulling them back but they are not very flexible and I am afraid I will snap them off.
abadfish66
#2 Posted : Saturday, November 8, 2008 8:16:26 AM(UTC)
abadfish66
Stick a screwdriver in there and turn it counterclockwise and the whole assembly will unscrew from the tub.
lgb1243@msn.com
#3 Posted : Saturday, November 8, 2008 9:38:13 AM(UTC)
lgb1243@msn.com
The arm came right out thank you for the reply. I see no buildup or blockage of any kind. Still get little or no pressure to lift rinser or spin arm. Am I now looking at a weak pump?
abadfish66
#4 Posted : Saturday, November 8, 2008 9:41:49 AM(UTC)
abadfish66
Put the sprayarm back in, start the washer, and when it's done filling tell me how much water is in there, you might not have enough water.
lgb1243@msn.com
#5 Posted : Saturday, November 8, 2008 9:47:18 AM(UTC)
lgb1243@msn.com
Doesn't seem to keep any water laying in the bottom. The only water is in the drain basin.
abadfish66
#6 Posted : Saturday, November 8, 2008 9:55:00 AM(UTC)
abadfish66
Can you hear it filling with water when you start it?
lgb1243@msn.com
#7 Posted : Saturday, November 8, 2008 10:17:05 AM(UTC)
lgb1243@msn.com
I don't hear it filling and it seems like it is pumping it out.
abadfish66
#8 Posted : Saturday, November 8, 2008 10:44:38 AM(UTC)
abadfish66
You need to figure out if it is draining while it's filling or is it just not filling?
abadfish66
#9 Posted : Saturday, November 8, 2008 10:46:32 AM(UTC)
abadfish66
If it's draining when filling, do this. Take off the kickplate at the bottom. To the left of the motor is the drain solenoid, is it melted and stuck in the down position?
lgb1243@msn.com
#10 Posted : Saturday, November 8, 2008 11:06:49 AM(UTC)
lgb1243@msn.com
It seems to hold maybe a 1/2" of water at most. Water has come in enough to raise the sprayer somewhat. Is the device in the front left corner a float switch? It seems to be draining and filling at the same time.
2 Pages12>
