The Temperature display for my oven is very faint. I can only see the temperature of the ovens if I put my hands around it very close. The time looks just fine. But for some reason the LED display for oven temp is almost not even there?
I have already replace the following parts to no avail:
AP3043893 (8300440) Control panel assy w/membrane, switch blk AP3598617 (8301848) Cntrl-elec
Any recommendations would be greatly appreciated!
Thanks in advance!
Brian
Looks like the parts listing is screwed up. The Control board you list looks more like a relay board than a control board. Did the control board you received have the display on it? This may help if you do not already have it https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdfIf not then I would say that is what you need. Sounds like it could be the transformer (Item 6 in Section 7) is no good. The problem here is that the display is OK when it shows the time. We cannot get actual board schematics but I would have thought that the drive for the display would be the same for time and temp. I could not see the tag in the picture of the part very good but it looks like it should be putting out 24 volts AC. |
THIS FORUM IS DEAD!!!!!!! |
