htpcdude
#1 Posted : Saturday, November 13, 2010 9:20:22 AM(UTC)
htpcdude
I have a problem with the water temperature selector on my washing machine. It only has hot water for the rinse cycle. I did a little troubleshooting.
Wash cycle
Hot => cool water
Cold => hot water
Rinse cycle, only hot water
I reversed the hot and cold at the water inlet.
Wash cycle
Hot, warm, and cool => warm to hot
Cold => cold water
Rinse cycle
Cold => cold water
I initially thought it was the water inlet value until I did the reversal test. So is the problem with some temperature sensor or control circuit? If so what part do I need and can someone provide some instructions on the repair procedure? I've replaced water pumps and timers on other units so I should be able to do this myself.
Thank you,
paclight
#2 Posted : Saturday, March 3, 2012 6:23:53 AM(UTC)
paclight
Hi , Htpcdude, my washer also has exactly same problem. Rinse only has hot water..
Did you already fix this problem?
Looking forward to your advice.
Thank you .:)
Whirlpool Cabrio water temperature problem (Washer Repair)
by Dave67AZ 8/19/2014 4:12:39 PM(UTC)
Water Temperature Problem (Washer Repair)
by Gerry434 7/30/2009 5:53:02 AM(UTC)
