Rank:: Member
Water spilled on the stovetop and leaked under the control panel. I need instructions to access the electronic panel (which screws to remove, etc). This happened once before, about a year ago, and I don't recall if the repairman replaced the control panel - other repairs were needed then too. I just want to check for standing water before calling for service, as it's an expensive part and repair. Thanks.
