Hello,
The front left burner will not ignite when the knob is turned on. Yes the gas is flowing to it. However, when I turn on any other knob the igniter on the front left ignites and the burner works fine. I am assuming it is something in the knob assembly?
I am forced to light another burner in order to use the left front burner. Any help is greatly appreciated.
Scott
Scott Scott, You could have a valve igniter switch problem, The switch should indicate a closed circuit, on a meter, when knob is turned to the "lite" or "On" position, Part number: AP3783914
If the switch circuit checks proper, you will need a new spark module. Part number: AP3778816
Good Luck, :cool: :cool: :cool:
Thanks Joe. I'll check it out. I appreciate the quick response.
Originally Posted by: hawknlv Thanks Joe. I'll check it out. I appreciate the quick response. You're welcome, Let us know how you made out. :cool: :cool: :cool:
