ish2008
#1 Posted : Thursday, October 14, 2010 8:39:44 AM(UTC)
ish2008
my garbage disposer emits this bad odor and white smoke when i tried to unclog it with the key and pushing the little red button underneath. Does this means capot.?
Thanks.
magician59
#2 Posted : Thursday, October 14, 2010 9:49:49 AM(UTC)
magician59
Did you pour any liquid drain cleaner into it?
ish2008
#3 Posted : Thursday, October 14, 2010 7:02:41 PM(UTC)
ish2008
No, No liquid drain cleaner.
magician59
#4 Posted : Friday, October 15, 2010 6:04:51 AM(UTC)
magician59
Don't know what that smoke is; but if you can freely turn the motor by hand from below, and it isn't responding to the electric switch--either you have a faulty switch, or the unit needs to be replaced.
Leaking Garbage Disposer (Garbage Disposer Repair)
by ebdunn 9/27/2011 9:44:48 AM(UTC)
Garbage Disposer Turn Off (Garbage Disposer Repair)
by baldridge 2/14/2011 4:52:12 AM(UTC)
GE garbage disposer not working (Garbage Disposer Repair)
by jdgolf 12/25/2009 7:48:18 AM(UTC)
Ge Garbage Disposer (Garbage Disposer Repair)
by MILLERHOME 12/21/2008 6:08:46 PM(UTC)
by Clifton Addison 8/29/2008 8:32:54 AM(UTC)
by Clifton Addison 8/29/2008 8:23:39 AM(UTC)
Garbage disposer (Garbage Disposer Repair)
by bstoffel 7/22/2008 4:46:40 PM(UTC)
garbage disposer hums and no longer works (Garbage Disposer Repair)
by blawden 5/1/2008 12:30:48 PM(UTC)
Garbage Disposer leaks (Garbage Disposer Repair)
by papasmurf 1/2/2008 2:22:53 PM(UTC)
