the wate wont stop running
THIS FORUM IS DEAD!!!!!!! |
I would take the bottom panel off. if you have a meter find the water valve connection. Run your leads to each side and have your meter on ac voltage. If the voltage reading stops after a few min of filling but the valve keeps pumping water then you have a bad water valve that is staying open. If wv and float checks good then it gonna be in the control panel
