crt
crtcn
#1 Posted : Monday, September 29, 2008 4:55:19 PM(UTC)
crtcn
Changed heating element last week. The old one burnt in two. The dryer works but it seems to be to hot. I checked both thermostats with an ohm. meter. they both were at .3 ohms
libertyappl
#2 Posted : Monday, September 29, 2008 6:17:07 PM(UTC)
libertyappl
Did you check them with the wires disconnected? Sounds like the high limit isn't working.
crtcn
#3 Posted : Monday, September 29, 2008 6:32:09 PM(UTC)
crtcn
Yes, when I tested the switches they were unpluged.Can you give the part # for the high limit.
libertyappl
#4 Posted : Monday, September 29, 2008 6:35:45 PM(UTC)
libertyappl
Your model number doesn't pull up, please verify the number.
Nat
SublimeMasterJW
#5 Posted : Monday, September 29, 2008 7:34:35 PM(UTC)
SublimeMasterJW
It should not exceed 165ish. If it does then your cycling thermostat needs replacement.:D
Ge elecrtic oven (Dryer Repair)
by moby2000 10/25/2012 9:38:27 AM(UTC)
Elecrtonic control board LED is out again. (Oven Repair (including Ranges and Cooktops))
by Honeydo 7/30/2011 11:25:27 PM(UTC)
