donnao
#1 Posted : Tuesday, September 18, 2007 1:16:12 PM(UTC)
donnao
How do I replace the dryer belt on my machine
swtmama5
#2 Posted : Sunday, January 27, 2008 11:01:43 AM(UTC)
swtmama5
How do you replace the belt for the drum in your dryer:eek:
#3 Posted : Monday, January 28, 2008 3:19:28 AM(UTC)
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
How to replace dryer belt on MDE9206AYW (Dryer Repair)
by qtlee 1/30/2011 9:38:51 AM(UTC)
need to know how to replace dryer belt/with photos if possible (Dryer Repair)
by lindasilverlady46 6/30/2008 7:43:53 AM(UTC)
