techsan47
#1 Posted : Monday, September 13, 2010 11:04:58 AM(UTC)
techsan47
Top burner igniter problem: 2 of the igniters work, 2 don't, but the two that don't work spark the Igniters on the wrong burners (the ones which will light if their respective knobs are turned). What part(s) do I need to replace?
Joe / APP Team
#2 Posted : Monday, September 13, 2010 11:38:34 AM(UTC)
Joe / APP Team
As long as the burner base(s) and the igniter(s) are clean and not corroded, you most likely will need a Spark Module.
Part number: AP4108240
To access the spark module,
You will need to remove the cook top and burners.
Remove the right side panel.
The Spark module will be located on the bottom base frame near the rear leg of the chassis.
Good Luck,
