Dryer burner lights for maybe 1-2-3 or cycles and on next cycle igniter glows but burner does not light off. If burner does not light a very slight shuttering sound can be heard around the main gas valve on dryer before igniter glows. I know there are 4-5 different things can be the main problem that can be checked with a continunty check but am not familer with the location of the components to check. The shuttering may be a clue to the root cause. All dust and lint has been cleaned throughout the whole dryer. The dryer is a Imperial series/commercial quality super capacity plus/7 cycles/4 temperatures. :confused:
