no1but24
#1 Posted : Saturday, August 28, 2010 1:29:16 PM(UTC)
no1but24
Hello, My Mircowave runs but does not heat, I checked the fuse and its fine i read somewhere that the magnetron tube is usally the issue, what do you guys think ?
Elayudante
#2 Posted : Sunday, August 29, 2010 4:12:41 PM(UTC)
Elayudante
Did you fix it?
I'm having same issue with a Maytag
no1but24
#3 Posted : Wednesday, September 1, 2010 6:57:44 PM(UTC)
no1but24
I replaced the magnetron and still doesn't heat, so I tried popcorn mode just for kicks and it said sensor error on the panel, I looked up the diagram online and there are 2 sensors, a gas sensor and flame sensor any Ideas ?
tkirkey
#4 Posted : Saturday, January 9, 2016 9:57:03 AM(UTC)
tkirkey
I have a 2007 GE Monogram Mircowave. Model ZE2160SF04. It stopped heating and makes a buzzing noise? Wondered if you can offer advice on fixing or replacing?
bjenk
#5 Posted : Wednesday, January 27, 2016 6:42:14 AM(UTC)
bjenk
My GE Space Saver microwave model #JVM 1542 BF 001 comes on make a loud buzzing noise , no heat can you help me ?
rohans
#6 Posted : Wednesday, January 27, 2016 8:10:15 AM(UTC)
rohans
Typically when a microwave is making a loud buzzing noise and is not heating, there are 3 things you will want to check to diagnose the problem:
1. The magnatron
2. The high voltage capacitor
3. Power Diode
brianv28
#7 Posted : Thursday, April 28, 2016 8:16:18 AM(UTC)
brianv28
Any chance it's the door switch? Mine was had a similar issue, light worked, exhaust fan worked, control panel worked, but the heating and the turn-table did not. Ended up one of the the door switches controlled only those two things. Easy to test for, and if that's what it is, cheap too!
