AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer won't stop filling, already replced pressure valve
water won't stop running. i replaced the pressure valve and the timer. Would it be the water dispenser valve
Originally Posted by: Peter Zantingh water won't stop running. i replaced the pressure valve and the timer. Would it be the water dispenser valve Peter, It could very well be the fill valve. Does the water stop, if you turn the machine off ? If the answer is yes, then it would be a bad water level tube(air dome hose)that attaches to the water level (pressure) switch. If you have to turn the faucet off, to stop the water going into the machine, then you definitely have a bad water inlet fill valve. Hope this helps. :cool: :cool: :cool:
Washer Repair
