Ref: GE Profile Refrigerator/Freezer Samsung Ice Maker Model : IMC701 GE P/N WR30X10097
After repairing a broken tooth on the geared wheel that dispenses the ice cubes I need to reinstall the drive motor but first I need to know how to locate the drive wheel. The wheel has a permanent magnet built in which needs to be properly located before I re-install the motor. What is the correct location for this wheel/dispensing arm?
PS Can you tell me the purpose of the little micro switch located on the side of the circuit board
Many thanks
[PHP][/PHP]Ref: GE Profile Refrigerator/Freezer Samsung Ice Maker Model : IMC701 GE P/N WR30X10097 After repairing a broken tooth on the geared wheel that dispenses the ice cubes I need to reinstall the drive motor but first I need to know how to locate the drive wheel. The wheel has a permanent magnet built in which needs to be properly located before I re-install the motor. What is the correct location for this wheel/dispensing arm? PS Can you tell me the purpose of the little micro switch located on the side of the circuit board Many thanks
