Hi, I have a water dispenser on the front of the fridge that is leaking. Everything seems to work fine (water and ice), but in between uses water is still dripping out of the water dispenser. I would like to order a part, but am unsure what would fix it. Thanks
Groups: Senior Expert, Administrators Joined: 7/19/2007(UTC) Views messages in topic : 27,455
Very likely the problem is a bad water inlet valve on the back of the refrigerator. - The water inlet valve Part number: AP3160649
