jill.lubich
#1 Posted : Wednesday, June 16, 2010 6:42:10 PM(UTC)
jill.lubich
My Whirlpool electric oven is not heating up for any settings (bake or broil). The oven is about 3 years old. The range and touch pad both work fine. I checked the thermal fuse - and it is still closed. I also have checked the heating elements and temperature sensor and all seem to be working (broil ~ 17, bake ~25, temp ~1080).
I have 240V coming into the terminal block (120V in each of two separate wires), but the thermal fuse, broil element, and bake element are all only receiving 120V. I'm pretty sure that the elements need 240V to operate - is this correct? What would be causing the elements to only get 120V?
Thanks for your help!
#2 Posted : Friday, June 18, 2010 2:16:39 AM(UTC)
Replacement parts for WHIRLPOOL RF362LXTS2 30" Electric Ceran Freestanding Range Self Clean Oven | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10135713A.pdf
And a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/5feedbe46138625985256aa1005ef62c/$FILE/8178042.pdf
[COLOR="Blue"]I'm pretty sure that the elements need 240V to operate - is this correct?[/COLOR]
Yes
[COLOR="Blue"]
What would be causing the elements to only get 120V?[/COLOR]
Probably getting it from the DLB relay contacts but the bake/broil relays are not closing.
Since the stove top elements and their hot surface lights work it does look like the power is OK.
Unfortunately it sounds like the control board is toast.
You could try the diagnostics to see if it comes up with anything.
I am assuming you have tried both bake and broil modes.
jill.lubich
#3 Posted : Friday, June 18, 2010 6:01:39 AM(UTC)
jill.lubich
Thank you for the resources!
That's what I was afraid of. Is there anyway that I can test the control board before I spend the $130 to replace it?
I did go through the electronic diagnostics screens. There was nothing unusual about it - no fault codes and no cleared error codes.
Yes, I have tried both bake and broil methods. Neither one will work.
Thanks again for all the help!
#4 Posted : Friday, June 18, 2010 6:54:45 AM(UTC)
[COLOR="Blue"]Is there anyway that I can test the control board before I spend the $130 to replace it?[/COLOR]
You ran the diagnostics and it came up OK, that is about all you can do.
Since you have doe a fair amount of troubleshooting, if you order the board from AppliancePartsPros and it does not fix the problem they will let you return it. See their return policy.
jill.lubich
#5 Posted : Friday, June 18, 2010 8:12:48 AM(UTC)
jill.lubich
Ordered the part today. I'll let you know if it works once I get it installed.
Amana electric oven not working (Oven Repair (including Ranges and Cooktops))
by marky mark 6/9/2008 6:10:38 PM(UTC)
