Over night the control assembly went blank. the stove works fine just no oven. Checked the fuse and replaced when pluged back in oven door locks still nothing on the control assembly. Would like to know if the hole assembly has to be replaced and if this will solve my problem Thanks.
dadspoerl wrote:
Over night the control assembly went blank. Would like to know if the whole assembly has to be replaced and if this will solve my problem
The control not lighting up at all can only be caused by it not receiving power for some reason (loose/broken wire, etc.) or a problem in the control itself. I don't see any other component in the appliance which would stop its operation. LINK > KitchenAid KERS507YWH0 Electronic Control, WhiteJMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
Thanks but the cost of the control assembly has me looking at a new range.
