AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Need wiring diagram for Kenmore 400 series dryer
Repairman said there should have been a diagram in the back of the unit but there isn't one. I need it to help him determine which part we may need to replace so the unit will work again. He found a switch that acts, we think, like a thermostat by the heater coil. It has no continuity in it, however everything else he tested does have continuity. Thanks in advance for any help that might come.
Originally Posted by: MarthaV Repairman said there should have been a diagram in the back of the unit but there isn't one. I need it to help him determine which part we may need to replace so the unit will work again. He found a switch that acts, we think, like a thermostat by the heater coil. It has no continuity in it, however everything else he tested does have continuity. Thanks in advance for any help that might come. Martha, Do the "switches" look like this ? Part number: AP3094244
If so, you'll need this part. All thermostat "switches" should have a "Closed" circuit, at room Temperature. Apparently you have a heating problem with the dryer. We have no diagram for your dryer,available at this time< but this little bit of info, should get the servicer through the repair. Good Luck, :) :) :)
Yes, I have a heating problem. The unit tumbles but produces no heat.
I do not know what the part you sent me looks like. I will have to get the repairman out here again to have him take it out and compare to your picture. We were given a part # 3977767 by a help desk person we called. Don't know if they are the same part or not...
Thank you for your help Joe. If we have further problems, I'll be back :(, just don't know exactly when that might be.
Originally Posted by: MarthaV Yes, I have a heating problem. The unit tumbles but produces no heat.
Thank you for your help Joe. If we have further problems, I'll be back :(, just don't know exactly when that might be. Martha, The number they supplied you 3977767 , is a Hi limit thermostat (Only) Part number: AP3131941
When you replace the hi limit thermostat, you also need to replace the thermal fuse, prt #3977393. The part number supplied to you has both parts( hi limit and thermal fuse). and should solve the problem. :) :) :)
Thank you so much Joe and Kyle for all of your help! I am so happy to be able to now get my dryer fixed! I love hanging clothes out during the summer, but drying sweat pants and shirts indoors in the winter takes a very long time!
I'm so grateful I found this site! I'll pass on to all my friends.
In great appreciation, MarthaV :o
Originally Posted by: MarthaV Thank you so much Joe and Kyle for all of your help! I am so happy to be able to now get my dryer fixed! I love hanging clothes out during the summer, but drying sweat pants and shirts indoors in the winter takes a very long time!
In great appreciation, MarthaV :o Martha, We hope all goes well, and you're up and running soon. Drop us a line, anytime you need an assist. Good Luck, :D :D :D
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Finally found a heating unit for my Kenmore 400 dryer. However, there are only 2 terminals on the new unit and 3 on the old. I am thinking the third terminal on the old unit is feeding somethning else on the drier as it is common to one of the supplies. Also, the old unit had something that may be some kind of limit and the new does not have this. And now, the "prongs" on the new unit are too large to rbpdruVPRecieve the female source connections. Woe is me! I am not an electrican and I am 90 years old. Help! George
Dryer Repair
