Had a power failure now the time does not display and dryer will not start. I can press the + or - keys on the control panel and i get a 1h through 10h on the display. Then I press the start button and it switches to 0:59 through 9:59 respectively. Not sure what this means. Do not get any error codes what so ever. Any help greatly appreciated.
Update: Put dryer into diag mode and getting F12 as error code which is no where to be found online or in the dryer manual. Help? Anyone? B)
Having the exact same issue. Did you ever figure out how to fix it?
Thanks!
Originally Posted by: Jbrew Having the exact same issue. Did you ever figure out how to fix it?
Thanks! Sorry no. Trashed dryer got a new one.
Joined: 3/10/2020(UTC) Posts: 0 Location: seattle, WA
I had the exact same issue, I found this in the technical service manual and luckily it worked for me.
Resetting the Modifiers and Options to Factory Default To return all options and modifiers to factory defaults, select the timed dry cycle, then press WRINKLE PREVENT, DAMP DRY SIGNAL, WRINKLE PREVENT, DAMP DRY SIGNAL, within 5 seconds. When done correctly, the 7-segment display will show “Fd” and the buzzer will sound before returning to Standby Mode. This procedure does not return the Customer-Focus
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
falkinm Thanks a lot, you saved me !!
