Ice And Water Dispensor Will Not Shut Off After It Is Activated. Jigggled The Control Door Several Times And Eventually It Stopped. Activated Again And Same Problem. Jiggled And It Stopped Eventually. Apparently Problem In Control Door Switch. How Is This Repaired?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Something is broken. You will need to take it out to find out what is broken.
